    Mar 2004
    mackem uk
    hi i have a avi movie and when i play it i get video but no sound.. (playing through wmp and winamp) so i put the file through g spot and it says i have the codecs to play this. when i put the file to rendre i get "render partial failure " any ideas guys thanxs
  2. sounds like the same problem i have if anyone can help its doing my head in.No matter which programme i convert from avi to mpeg with film converts fine but there is no sound whatsoever
    anyone help us pleeeeeeeeease
    Dec 2002
    My Swamp
    What sort of audio does Gspot say you have ? AC3 , Mpeg1Layer3 .
    Also what software are you using to encode ?
    Mar 2004
    mackem uk
    sorted it thanxs i had to put it through v/dub and made a wav thanxs again
