Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Hi there!!
    I`m kinda of a newbie on video editing but I`d love to make some DVDs out of my old VHS tapes.
    So I`d like some advice on WHAT is the best software for remastering the video? I mean, applying filters, sharpen the video a little...?
    oh, I'd also love to know what's that filter they use A LOT these days on videoclips and movies (Charlies Angels for example). It makes everything look bright, colorful and smooth!
    thanx for any info
  2. So I`d like some advice on WHAT is the best software for remastering the video? I mean, applying filters, sharpen the video a little...?
    I'd suggest the search filter. You also have to capture
    the video before you filter it; so search on capturing as well.
    When you have read up a bit you will be able to be more concise
    with your questions and you will get more help.
    It's called Digital Video
  3. thanx for being so kind...
  4. you are welcomw
