Hi,
I have two DVDs where each has three movies burned into it - presumably by using DVDShrink or something like that.
I want to take the first two movies from DVD 1 and the third movie from DVD 2 and burn them onto another DVD with a front end menu to select the relevant movie.
So I have on my hard drive the following VOB files
For movie No 1 VTS_01_1 and VTS_01_2 from DVD 1
For movie No 2 VTS_02_1 and VTS_02_2 From DVD 1
For movie No 3 VTS_03_1 and VTS_03_2 From DVD 2
What is the best way / software to use to build a menu for this. Would I still have to demux the VOB files?
Would I still have to demux the VOB files? -
Thanks for the advice.
I've burned the DVD with DVD-LAB, which plays fine.
However, when I play the DVD with PowerDVD and try to use the navigational slider, nothing happens. It just carries on playing.
If I open the VOB file direct from PowerDVD, the slider works. With the little knowlege I have, I'm assuming there's something in the IFO files that's making this happen, but I can't see any settings that might overcome this when compiling the DVD.
Any suggestions
Thanks in advance. -
I assume you imported the VOBs without multiplexing. I've never thought that was a good idea (doesn't mean it won't work but navigation problems are quite probable as you've experienced). Perhaps I shouldn't have suggested DVD-Lab.
Despite that some people think VOB is just a different mpeg file, it contains far more stuff than a normal mpeg system stream. One should either import a VTS structure as a whole (if the application can read it) or demux the VOBs before importing.
Try TMPGEnc DVD Author. It can read and import an entire VTS. If you only use DVD-Lab demux the assets first, extract the chapter points (with ChapterXtractor, for example) and import them into DVD-Lab.
Did you try playing the DVD in a standalone? Standalones navigate slightly different from a software player so it may be OK.
Building an HTPC
By joepic in forum Media Center PC / MediaCentersReplies: 6Last Post: 16th Feb 2016, 16:46 -
Help building pc.
By A Traveller in forum ComputerReplies: 8Last Post: 25th Oct 2009, 15:56 -
Building a PC!
By Nitro89 in forum ComputerReplies: 16Last Post: 4th Nov 2007, 14:42 -
Questions about Building my first PC
By navi310 in forum ComputerReplies: 18Last Post: 28th Aug 2007, 19:07 -
Building Grids
By Busman in forum Newbie / General discussionsReplies: 5Last Post: 17th Aug 2007, 23:44
