I have been converting avi to SVCD using AVI2SVCD quite happily for sometime now. I am quite a newbie so I found this programme did everything for me regarding changing NSTC to PAL, ripping off the sound etc. However I recently purchased a DVD burner and I wondered if there was a programme out there that could do the same job and convert to DVD. I have tried AVI2DVD but it requires Sonic Scenarist which is quite expensive - any other suggestions.
Many thanx
Results 1 to 13 of 13
Thanks for that - however I have already looked at most of these guides and they all involve using several different programmes. Maybe I'm being too dull as a newbie - but most of these programmes confuse the hell out of me. What I was looking for was a nice simple programme like AVI2SVCD which will do it all for me. AVI2DVD will but it means buying Sonic Scenarist which is expensive - so my questions was is there another programme like this one or is there a way I can use another programme instead of Scenarist which is free or shareware.
Thankx -
Probably the easiest to learn would be
TMPGenc Plus ( 30 Day Trial for Mpeg2 )
TMPGenc DVD Author ( 30 Day Trial )
Burning Software e.g. Nero which you probably already have
There are plenty of good guides for TMPGenc and Author and you can use them for a month to see if you get on together. -
I cheat. Both my cheap players will play PAL on an NTSC TV (mechanical conversion on the fly). This makes it real easy :P In fact, I have a fair number of mixed NTSC/PAL DVD's. TMPG Author is my primary DVD building application.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Typical newbie...always looking for one click solutions...anyway...
I'll agree with TMPGEnc Plus and TMPGEnc DVD Author. I'm afraid that I'm not aware of any one click solutions that do what you wish to do. You may have to get your hands a little bit dirty I think.If in doubt, Google it. -
Originally Posted by jimmalenkoI think you need to make the 'Never' in your signature a bit bigger.Originally Posted by jimmalenko
I just found a guy asking if his DVD Player will playback VCDs.
It took me a couple of minutes on google to say 'NO' -
Brilliant !
I nearly fell out of my chair - I'm pretty sure that'll get noticed. LOL . -
It is more aimed at my work - tech support in a bank. I have found that the minute you think "I'll just click these two things to frix the problem" is the minute that you have to remap a drive, reconfigure their email, install a SP and so on and so on. I guess it still rings pretty true in the world of DVD also.
Dude, there are two scenarios to this:Originally Posted by Lynxer
1. Spend the money to buy Scenarist and you will have yourself a one click solution,
OR
2. use multiple programs and actually "understand" what they are doing. Follow the plethora of guides here. Do exactly what the guides say.
Just as a footnote, you really aren't going to go far in the world of DVD if you are looking for one-click solutions without paying for them. I guess if it floats your boat the fair enough. Just remember that we are doing some pretty complex stuff here so if you're up for a challenge, go forth !If in doubt, Google it. -
If you've got Nero 6, give Nero Vision Express a shot. Works pretty well most of the time, is easy and yields pretty good results considering it's pretty much a one step process. You can merge and add chapter stops also. You can get the demo and give it a shot.
You dont have to buy Scenarist to use DVD2SVCD. Just go to the CD Image tab and select "Dont Make Images", then once encoded, use Maestro, DVDLab or TMPGEnc DVD Author to author the files ready to burn.Originally Posted by Lynxer
cm
Batch convert DVD folders easily?
By tomkat2010 in forum Video ConversionReplies: 3Last Post: 6th Mar 2012, 19:10 -
Best freeware for converting MTS to easily readable format?
By mccake in forum Video ConversionReplies: 1Last Post: 8th Dec 2011, 05:48 -
Any advice on how to split a large AVI into smaller clips easily?
By Bluelude1 in forum Capturing and VCRReplies: 11Last Post: 19th Jun 2011, 12:55 -
Best/Fastest way to easily convert a dvd (.VOB) to .avi
By xxnonamexx in forum DVD RippingReplies: 21Last Post: 4th Sep 2010, 13:17 -
How do I easily convert DVD (.vob) to XviD AVI?
By innovyse in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 20:15
