Hi,
I used one of the method suggested as follows to convert the avi file to vcd
1. I use VirtualDub to extract the sound to a wav file
2. I then use TMPGEnc to convert the avi & wav to VCD
3. When I play the files on my computer or vcd player, some of the video quality goes blank at times but the sound continues to play
This does not happen when I play the avi file. Is there anything wrong with the conversion process?
Conversion seems fine - have you checked for bad frames using vdub ?
Edit : Snap -
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
Hi,
May I know how do I do that in VirtualDub?
The avi is perfectly OK in terms of sound & video quality.
Originally Posted by Lynxer -
Open the movie in vdub. Video > scan for errors. If it reports back bad frames you'll have to cut them out. There are guides on the left that explain how to do this.
Download Virtualdub and Virtualdub MP3 freeze from the tools section of this page. Open MP3 freeze and load the avi and then under the video tab at the top select check video for freezes then open Virtualdub and under video select scan video stream for errors.
If there is a freeze or any bad frames these will need to be deleted before you can encode to vcd or svcd. -
Have you tried Vdub MP3 Freeze - this checks for video freezes which you avi may have even if it does not have any bad or undecodable frames.
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 2nd Aug 2007, 00:41
