I have purchased a 2HP case fan for my computer and installed it at the back to draw air out for cooling. The problem is that the force of the air is pushing my computer off the desk. I have tried holding it down with a old printer, but no luck. What do you guys use? The place where I bought it warned me that if I block holes in the front of the computer it will collapse the sides eventually. Has this happened to anyone?
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
The the heck kind of fan do you have?The problem is that the force of the air is pushing my computer off the desk.
I would think it is an April 1st modelOriginally Posted by nissmo300
Yes, I am a Pooternerd -
Don't worry, when the computer implodes it actually resides in the 8th dimension. Your cables will seemingly disappear into nothin but they're still connected. Fortunately things are nice and cool in the 8th dimension so your computer should perform a lot better. The only thing you need to watch out for is ed Lectroids. They're a warmongering alien race from the 8th dimension but they're kept in check by the Black Lectroids. You're lucky, normally it takes an oscillation overthruster in order to transport things to the 8th dimension, but apparently those brand of fans were used to cool the said overthruster. Maybe it's actually just the fans that are what causes it?
Case fan not spinning
By beavereater in forum ComputerReplies: 18Last Post: 15th Sep 2011, 14:51 -
problem playing MKV file on a strong computer
By tomchook in forum Software PlayingReplies: 9Last Post: 25th Mar 2010, 18:53 -
How strong laptop do I need to capture HDV
By Cazz in forum Capturing and VCRReplies: 5Last Post: 7th Jan 2010, 09:26 -
Problem Printing DVD Case Insert
By boofer in forum MediaReplies: 7Last Post: 30th Jan 2009, 22:41 -
FFMPEG x to PAL-DVD, strong deblocking ?
By halsboss in forum Video ConversionReplies: 7Last Post: 3rd Apr 2008, 04:52
