Just noticed that SVP have started selling this stuff. Never had a problem with water and dvds, so is it worth the hassle and mess ???
{AC 5065} Satin - Inkjet Fixative Spray - 300ml
Inkjet fixative is a fast drying satin spray for fixing inkjet inks. It may be used on most papers and discs after printing but it is always advisable to test materials for compatibility before use.
Price: £4.99 Including VAT at 17.5%
Not bothered by small problems...
Spend a night alone with a mosquito -
not if you never had a problem ...
but it does work well -- just a pain if your doing say 100 disks .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I think I have found the best spray!!
By RickTheRed in forum MediaReplies: 113Last Post: 22nd Aug 2011, 01:54 -
caught a kid spray painting a neighbors car (vandalizing)
By zzyzzx in forum Off topicReplies: 12Last Post: 18th Oct 2008, 12:59 -
Spray on DVD media
By lin in forum MediaReplies: 15Last Post: 25th Dec 2007, 02:45 -
By werewolf_02 in forum MediaReplies: 22Last Post: 17th Jun 2007, 21:55
