Hi:
how I can ripping the karaoke I like from vcd?
I have tow karaoke vcd ,but I only like some of them,
how can I copy out the one I like and put it in one
karaoke vcd?
thx
just copy "dat file" in folder mpegav. copy only the songs you want then use VCDGEAR to convert back to mpeg file and burn all of them together in vcd format.
then copy that one dat file. Convert to mpg file with VCDgear. Last cut each songs in TMPGenc (under mpeg tool). All softwear you can find under Tool section (left side). Hint use VCDGEAR GUI if you're not used to with command line.
Ripping dual audio tracks Karaoke DVD
By Longhorn1955 in forum Newbie / General discussionsReplies: 3Last Post: 7th Dec 2011, 23:14 -
I need help with Karaoke DVD to Karaoke VCD(MPG)
By adrianneow in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2011, 09:02 -
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Aug 2010, 23:01 -
vcd karaoke to dvd
By pcb in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2008, 13:44 -
how to convert LD karaoke to VCD karaoke ???
By sandmankeren in forum Authoring (VCD/SVCD)Replies: 1Last Post: 7th Aug 2008, 15:53
