I don't have DVD2One unlocked to test this, and I don't know if an unregistered version will let me try. I have a DVD with menus, 4 half hour episodes of a TV show, and extras. I want to keep all of them, and the material totals 6.2 GB. Would DVD2One be able to recompress all of the material to bring it down to 4.2, or does that only work if there's a single movie on the disk?
yes it can.
you demo should allow you to run a test of the app, such that it cuts off at like 30 min or so
rip the disk over, do full disc copy and see how the demo handles it. -
Works perfectly on Farscape and Firefly. The Farscape discs are so expensive I use copies for EVERYTHING, just out of terror that they might get scratched.
If it isn't broken, take it apart and find out why.
blog: deadsierra -
What We Do In Life, Echoes In Eternity.... -
Is Wayne Brady going to have to get out of this car and choke a bitch?Originally Posted by Denvers Dawgs
My best answer for you is to try it. select the resulting VIDEO_TS in Apple's DVDPlayer and see how it looks. Burn to DVD-RW if you need to check it on your set-top. I've found DVD2One X has done a great job on most of my backups.It's a 2 disk series with 8 episodes on the 1st and 4 plus some bonus material on the 2nd. My question is if I just do a full dvd srhink using dvd2one, will the video quality be horrible. I've used this method on the family guy series, but that is a cartoon and can't notice much of a difference.
:::edited for typos:::
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 11:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 11:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 07:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 17:11
