Having a problem now with DVDWS 2.01. I know what caused it somewhat, but don't know how to fix it:
I re-installed Windows XP over the old installation to fix a different problem. I lost some video and audio codecs but got those again. Now i'm having this error come up (in addition on the error window, it shows the path to the DVDWS.ini file) when I open the program. I'm sure it has something to do with my re-install of WinXP. I'm unable to open mpeg files now because of it. Any ideas?
Although I saw no mention of your problem under Ulead DVDWS2, I did find something about it under version 1:
Click here to go that page.Mpeg Vio Driver Update Patch (Released Date: 2003/1/16)
Fix "Load Mpeg Vio Driver Error" when you launch the program on Windows 98/ME.
Fix "Load Mpeg Vio Driver Error" when you install both Ulead program and ADOBE Premiere 6.x onto the same system.
Could it be possible you upgraded from a earlier version?Hello.
MPEG Streamclip: "Audio Decoding Error"
By addresstom in forum AudioReplies: 3Last Post: 30th Aug 2011, 11:12 -
I get a "could not load codec settings" with Fairuse Wizard
By felix in forum DVD RippingReplies: 3Last Post: 29th Apr 2011, 12:10 -
AVS Video Editor Blu-ray verification slow and "driver package" suggested.
By rjamesd05 in forum Authoring (Blu-ray)Replies: 0Last Post: 26th Mar 2010, 08:01 -
Cant Play / Load A RAW DV file "Codec Status Undetermined" Please
By hypnoticpimp in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2009, 15:29 -
HCenc "Invalid MPEG-2 Frame rate" error.
By Maikeru-sama in forum Video ConversionReplies: 24Last Post: 8th Jul 2008, 19:09
