I've been trying this for weeks. I have vegas and a couple other program s but none of them are letting me to what i want to do. I want to import a clip (.vob file if possible) and fade the end of the clip (audio and video) keeping the original picture quality and 5.1 dolby digital ac-3 stream.....
Any Ideas??
thanks
There's your problem - you can't edit AC-3 audio in Vegas.
You'd need to break the 5.1 mix into separate channels and essentially remix it (in Vegas) and then re-encode it with the AC3 plugin. What you mention isn't very easy, it just takes time. -
You won't be able to keep the original picture quality and sound quality - they will both have to be recompressed, unfortunately.
does anyone know if there is a guide available to show u how to do that in vegas??
avisynth to fade audio but not video
By adom in forum Video ConversionReplies: 9Last Post: 5th Oct 2011, 16:51 -
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 13:45 -
Need to create a Blu-ray demo disc
By wiggin78 in forum Authoring (Blu-ray)Replies: 3Last Post: 17th Oct 2009, 13:35 -
Making a 5.1 Demo Disk
By Mooic in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2009, 15:34 -
how can I add "Fade in / Fade out" effect in my video clips
By mb508 in forum EditingReplies: 5Last Post: 9th Jul 2007, 17:02
