when i try to convert/edit my mpg it comes up and says error it cannot be created what should i do
Results 1 to 13 of 13
Originally Posted by jemel46Also are you trying to create a file with the same name and path as your source file, or does your destination really exist?If you get an error message when opening like file unsupported or can not open or is not supported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 2 or to the top of the plugin-list and try reopen the videoHello. -
Jimmalenko, was that really necessary? Look at the date he joined, and then deep within yourself. Then please ask yourself was that really what you really wanted to say?
Hello. -
if source EQ destination dosnt that EQ Update ?
p.s hey jemel46 keep slogging away m8 :P
