I get a No Disc message when I put a CD in the machine. The laser appears to be OK but the motor does not start. I can get a bunch of messages using the remote plus the front panel buttons. Can I troubleshoot this way or intialize the software (assuming it is corrupted)? What is the most likely cause if the motor does not start? Could it be the motor itself or driver circuitry. Any help on where to look next appreciated.
RobinB
Your motor is shot or sure ,if you really like the unit take it to an authorized repair shop its going to cost about $75.00 ,but for that price you can buy a new one...
Mine did that to, I just took the top off & gave that white circular cog a little push & its been fine. With the top off, keep your face from that laser eye.
Panasonic DMR EZ28 Won't Eject Disc, Keeps Turning On & Off
By Garyrajsich in forum DVD & Blu-ray RecordersReplies: 3Last Post: 11th Jun 2011, 19:19 -
Do Any Double Layer Disc Work With Panasonic DMR-EZ48V?
By cbehr91 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 10th Jun 2010, 16:39 -
Recovering 'Lost' Recordings on Disc in Panasonic DMR-ES30VS
By wellsie7 in forum DVD & Blu-ray RecordersReplies: 19Last Post: 10th Jul 2009, 02:16 -
panasonic bd35 and back up disc
By marky.b in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Feb 2009, 11:43 -
Panasonic DMR-HS2 gives me a U11 message when I try to put any disc in...
By garylime in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Aug 2007, 15:40
