has anyone ever tried running other programs while TMPGEnc Plus converts files........
i am so sick of 5 hour conversions and being afraid to run other programs because they might screw up the conversion process in some way.
any ideas? thanx !
Doing light stuff like surfing is not a problem, for more intensive stuff you might want to adjust the task priority under the "options" tab. Adjust it lower to give more CPU time to other programs.
"Art is making something out of nothing and selling it." - Frank Zappa -
i agree with the others. it wont screw up the encoding process but it will slow it down. just do all of your encoding when you go to bed and it will be ready for you when you get up.
Yep, everyone's got it exactly right. The only effect running other stuff will have is to slow down the encoding process.
I use Win XP Pro. And I run Seti command line client 24x7. But it runs at lowest priority, so I can do other stuff at the same time (including fairly CPU intensive games and stuff) and it'll just sit there in the background and use whatever CPU time is going spare. No problems.
But the first time I started encoding with TMPGEnc, I found that no matter what I did (i.e. setting the Process Priority in TMPGEnc), TMPGEnc would eventually revert to lowest priority too. So, instead of TMPGEnc taking priority over Seti, the two tasks would end up competing for the CPU and only get 50% each.
So now I have to shut my Seti task down, whilst I encode so that TMPGEnc gets all the CPU it needs to be able to complete in the shortest possible time.
But TMPGEnc still doesn't stop me from using the computer for doing other stuff at the same time, unless it's intensive stuff like running games.
It's only a minor inconvience (i.e. having to stop Seti and restart it afterwards), but I can live with it.
Ian.
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 17:51 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 20:59 -
TMPGEnc author4 running codec twice
By BRck in forum Software PlayingReplies: 2Last Post: 4th Feb 2009, 07:47 -
Laptop runs REALLY SLOW!
By Squid_uk in forum ComputerReplies: 22Last Post: 6th Oct 2008, 23:34 -
video runs slow
By Madgelina in forum EditingReplies: 0Last Post: 8th Feb 2008, 18:45
