I know how to burn mpeg or .dat into DVD-R by using Nero. But i want to have a menu so i use Neroexpress 2 but it only for cd-r?
so is there a way to make a menu?
Results 1 to 21 of 21
i want to burned 4 Movie into a DVD with menu.. so i use Nero Express 2.
You know in Nero Express 2 : Make DVD it seem they make my movie size bigger (suppose each of my movie is 1GB ) so it defenetely not work with 4movie in 1 DVD.
Ok i just want to have 4 movie in 1 DVD.. (czu those movie is mpeg or .dat file) -
First you´ll have to know if your video is DVD compatible (AVICodec for example). If Nero makes the files bigger has you´re saying it´s because it´s reecoding the files - meaning that they weren´t probably dvd spec to begin with (https://www.videohelp.com/dvd).
To author you need to have DVD spec mpeg files then use authoring software.
J -
my movie is Mpeg.. i can burned it in Nero without menu. But i want a menu with a selection. But if i go DVD-Videos File and drag my movie in there they double the size..
Plz help!! thx -
Forget the programs. You need to read more.
Originally Posted by Still Learning Here
My home's DVD Player Panasonic.. home system can't play the dvd that i created with my Lite-On 411s. I used DVD-R to create..
i can play in my Lite-on but not my DVD Player. I'm sure my panasonic dvd player support DVD+/-R
UPDATE: I failed 3 dvd..
first dvd i use TMPGEnc DVD Author to burned.. and my panasonic player can't play it.. (Sky Pro brand DVD)
second DVD (i forgot what brand this dvd) i used Nero to burned.. using DVD-VIDEO and drag the VIDEO_TS folder in..
third DVD (Ritek brand) i use Nero.. it still can't play
all burned in 2X.. (all sucessfully burned.. 100% no cluster or anyhting.. or even moving my mouse while burn) ..
plz help.. thx -
my fourth attempt to burned this DVD..
now this time iwth no MENU and it work on my Panasonic Player!! BUT!!! every 5second it skip.. and there is a noise..
I test the DVD in my Lite-on DVD-RW and it work fine.. so plz for god sake help me!! thx -
Originally Posted by Aznmask
It also seems you're using cheap media.Want my help? Ask here! (not via PM!)
cheap media? Ritek.. if you think that is cheap.. then i have nothing to say.
Anyway my cousin's Yamaha DVD Player home system can play those DVD. While my Panasonic can't even play any of it.. (I'm sure my panasonic support dvd-r or dvd+r.. czu i back up some of my DVD but it is 1:1 Copy) -
What model is your Panasonic(exact model number)? Search for your model in this list here and see what your dvdplayer support ==> https://www.videohelp.com/dvdplayers.
It's not best, no.
But I think your problem is in authoring or the player.Want my help? Ask here! (not via PM!)
not Ritek fault!!.. not my fault!! not my Panasonic's fault it is Lite-On 411S's fault!
Since my pc was network with my cousin's . So i have his Sony 8X dvdrw to burn.. and it work in my Panasonic!!
I just bought this Lite-On.. 411s no wonder they sell for $77.. -
Firmware error ?
i upgraded this DR4FS0J firmware on last week.
does anyone know how to fix this??
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
DAT to MPEG 1
By MI6 in forum Video ConversionReplies: 14Last Post: 8th Feb 2009, 15:01 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 26th Sep 2008, 23:18 -
dat to mpeg - no sound
By goshz in forum Newbie / General discussionsReplies: 9Last Post: 22nd Jun 2007, 04:24
