Hi,
I have a video with a .mpeg extention. However when i check the video using G-spot, it says "video/x-ms-asf".
When i try opening it using Virtuedub, it wouldnt open cause wrong compression pack or something.
How do i convert this to make a vcd?
thanks
nite,
Have you tried just feeding the file into TMPGEnc? It may well accept it. Here's the guide to converting .AVI to VCD using TMPGEnc (this also covers conversion of .ASF video files):
https://www.videohelp.com/tmpgenc.htm
Try this method and see if it works.
Cobra -
most likely someone tagged the wrong extention on it. its ASF. V Dub won't open ASF I think because ASF is a microsoft certified format that cannot legally be edited by unlicensed software.
Just to add to that, VirtualDub 1.3C was the last version with ASF support. Anything before this will open ASF. You can still find it on the net ig you look hard enough.Originally Posted by Poppa_MethIf in doubt, Google it.
How can I convert ASF file?
By QuattroNN in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2011, 14:11 -
.asf file will not open
By powrslave in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 11:56 -
help on .asf file conversion
By fabpozzi in forum Video ConversionReplies: 5Last Post: 23rd Jun 2008, 20:13 -
Conversion from asf files to avi or mpeg
By Jescal in forum Video ConversionReplies: 1Last Post: 23rd Jan 2008, 17:37 -
ASF file conversion
By sawm24 in forum Video ConversionReplies: 7Last Post: 11th Aug 2007, 09:47
