    Mar 2004
    Canada
    I have an avi file. I was told to use tmpgenc dvd author to convert it to a vob and then drag the contents of the vob file into video ts folder in Nero. So I installed tmpgenc dvd author. I went to add file. It wouldn't accept my avi file. Said only mpg 1 or 2. I thought the whole point of tmpgenc was to convert avi files.
    Basically, all I want is to take my avi file and burn it to DVD.
    S.O.S. can anyone help?
    Burning to CD-Rs I have down pat, but burning to DVD-Rs I need help with.
    Wendi
  2. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    What are you doing? Where are you adding your file? Are you encoding it first or are you trying to author an AVI file - that won't work.
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  3. The TMPGEnc video encoder will convert your file, not TMPGEnc DVD Author.
  4. Well, tmpgenc plus will convert it to mpg2, but you'll still probably need an authoring program (like tmpg author) to make vobs
    Mar 2004
    Canada
    I understand it is like this: I take my avi file into tmpgenc (can I use tmpgenc plus???) and use it to convert to mpg, then I use tmpgenc dvd author to convert it to vob ( how i do that exactly I am not sure), then I drag the entire contents of the vob file into Nero video ts folder and burn to DVD? OMG - what a few steps.
    Can I use tmpgenc plus to convert the avi to mpg? Does it actually work?
    And I am unclear about the dragging the entire contents of the vob file (after tmpgenc dvd author changes the mpg to vob) into Nero video ts file?
    Signed,
    Eager to learn this
  6. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Capture>Encode>Author>Burn
    That's the process.
    Yes, TMPGEnc Plus will encode your file to a DVD legal MPEG2 just fine.
    Once you author your DVD title set, (the VIDEO_TS + AUDIO_TS folders you are confused about) you use a burning program like Nero to actually put them on DVDr media.
    Tons of guides here. Check 'em out.
    Mar 2004
    Canada
    Hello everyone!
    I just wanted to thank everyone who helped me. I have it all figured out now and am watching DVD-Rs I burned on a standalone dvd player / television. I made extensive notes with print screens on how to do it, so it anyone wants a copy let me know at: cleotay98@yahoo.ca
    Thanks again!
    Wendi
