I have two 715mb XViD avi files that I would like to convert to mpg2 and burn a standard DVD. Is the best way to just use the project wizard in TMPGenc and set the "make file size" to 50% of the DVD for each avi? Doing this way yields almost 3mb/s bitrate. Or should I join the two avi's together (if so, how?) Or is there another way to do this? My ultimate goal is to make one DVD rather than two SVCDs if that helps...
Thanks!
I would encode each file separatelly. Don't set the final size for each file to 50% of the DVD size, rather check the duration of each file and use the duration as a measure of the percentage of the DVD disk size.
E.g. If file 1 is 40 min. and file 2 is 35 min, then
file 1 final size should be 40 / 75 X 4.3Gb and File 2 final size should be 35/75 X 4.3Gb.
Also, it's best to use VBR single or 2 pass.
Also, check the frame sizes of the files and ensure that the encoded file will have a legal DVD frame size (although I guess the Tmpgenc wizzard will do that for you).The more I learn, the more I come to realize how little it is I know.
TMPGenc 4.0 Xpress can't encode AVI with 16:9 display
By Sanderverbeke in forum DVD RippingReplies: 2Last Post: 23rd May 2010, 07:21 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 16:03 -
WMV and MPG to Xvid or MPG2?
By videohalp in forum Video ConversionReplies: 2Last Post: 27th Sep 2008, 23:16 -
Easy way to encode .m2ts (bluray) files -> mpg2?
By z0diac in forum Video ConversionReplies: 3Last Post: 21st Feb 2008, 10:05 -
Strange problem converting Xvid AVI to MPG2
By joelore in forum Video ConversionReplies: 18Last Post: 1st Jun 2007, 23:40
