Hi to all I want to know if I get the same same same quiality capturing form my Studio DV 8 Card and my MSI Motherboard Firewire port. IS REALLY the same quality? . I know that both are Firewire ports,.but who knows....
There are DV codecs that can capture in better quality?
Thanks a lot
Hernan
When transferring from camcorder to PC there is NO codec involved. The camcorder has it's own codec and the DV transfer is just that, a transfer (like a file copy). If you want to use the DV file as input to something else, like TMPGEnc or VirtualDub, then you need a codec.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Built In Multiple Card Reader Won't Recognize SD Card
By V Bot in forum ComputerReplies: 9Last Post: 8th Oct 2011, 00:01 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 16:51 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
