A newbie using TMP to convert an avi file to play on my stand alone dvd. seems to do everything according to hoyle but when I try to play it in my dvd I get an error message that is a grey screen that says mp3/ control. My dvd plys other svcd. what step am I using i have xp on my computer.
One other thought I also used curosoft(?) and got the same message.
Sounds like you burned the svcd file directly to the cd, and your dvd player recognize it as a data/mp3 cd. SVCD must be burned in mode2, not as data (mode 1), use for example VCDEasy or something to create SVCD, even Nero can do it if you choose svcd as project type, just dont let Nero **** it up by reencoding it, its not a program that like you to make your own choices.
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 15:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 12:41 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 2nd Aug 2007, 00:41 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22
