Has anyone noticed "chunks" of color appearing while watching a dark scene on your DVD player?
I´d like to know what´s the most likely guilty part: dvd player, S-Video cable or TV (Trinitron bit worn out).
Regards
J
I doubt it's your cable.
It MIGHT be your TV. Who makes the DVD player? -
Macro blocks. Comes with mpg compression. The lower the bit rate, the more obvious the macro blocks.
/Mats -
maek
It´s a Pioneer and one of the good ones 2-3 years ago.
mats.hogberg
I don´t think they´re macro blocks. This happens on comercial DVD´s even the one´s that have great quality and only in dark scenes - if it were macro blocks shouldn´t it be visible in all mono color scenes and fast action scenes?
J -
Hmm, no obvious solution then.
Have you tried troubleshooting it? For example, have you tried hooking it up to different TV's? -
/Mats -
Originally Posted by mats.hogberg
Panasonic AG-1980 "Color Banding"
By mugenmidget in forum RestorationReplies: 5Last Post: 2nd Jun 2010, 09:32 -
DVD-lab PRO v1.6 - "Map" only gives the color black
By Paker in forum Authoring (DVD)Replies: 1Last Post: 3rd Sep 2009, 13:30 -
Auto-split 10 hr capture in 3 min chunks "on the fly"
By atvmxr in forum Capturing and VCRReplies: 2Last Post: 22nd Apr 2008, 09:48 -
"inverted" color screen on laptop. Help??
By Super Warrior in forum ComputerReplies: 5Last Post: 18th Mar 2008, 18:51 -
"chunks" cannot get my .VOB file to split into .DV chunks
By system9 in forum ffmpegX general discussionReplies: 2Last Post: 12th May 2007, 17:53
