Ok i have an avi that is captured from my DV cam. I want to export some of the frames to some photo editor ( say Adobe Photoshop) do some editing on then and then import them back to avi.
How can that be done ?
what software(s) will i need ?
I have U lead visual studio, Virtual dub, MovieDV suite, adobe photoshop 7.
I have searched the guides also but could not find any.
Any little can be useful.
TIA
Saurabh
Hard work never killed anybody,
But why take the RISK -
Open your movie with Virtualdub, go to "Video" and select "Copy Frame To Clipboard", then paste into your photo editor. If you receive an error when opening your movie in Vdub you'll probably need to install a DV codec such as the Mainconcept DV Codec. I'm not sure how you would put them back into the avi though. I would imagine it can be done with Premiere.
Thanks teegee,
I dont get errors while opening the avi file in Virtualdub and i think copying frame from the movie wont be a prob either.
Now the tricky part is to get that edited frame back to the avi, hoping to get some help on that also.
SaurabhHard work never killed anybody,
i think there are 2 options:
1)
- save frames as images and edit them
- import movie and cut out unneeded frames
- insert the images where needed
- export movie
2)
use frame editing.
this is much more puwerfull, but mostly not supported by low priced software.Music was my first love, and it will be my last -
Hi saurabh_fzr,
Originally Posted by akbor75There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
You can tell Vdub to output a selected range of frames to
bitmap files. It will also import a bunch of bitmaps into an AVI
help needed to identify video editing software
By keith roberts in forum EditingReplies: 12Last Post: 5th Feb 2012, 12:06 -
help needed converting and editing an flv please
By Witzend in forum Newbie / General discussionsReplies: 6Last Post: 23rd Aug 2011, 15:04 -
Help with capturing/editing needed
By Nilfennasion in forum MacReplies: 2Last Post: 24th Aug 2010, 11:25 -
Help needed with Editing and Authoring AVCHD
By chrisdhall in forum EditingReplies: 2Last Post: 20th Apr 2010, 03:39 -
Help needed with HD camcorder, PC and editing software choice
By Paul Tyrrell in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2008, 15:02
