i am working on a DVR(digital video recorder) apllication which uses a 40 GB hard disk for storing streaming MPEG4 data,as the max file size in FAT32 system cam me 4GB(3.99 GB), and the recording stops at that time, i need some tricksas how to over come this problem and i can't change the file systems(FAT32to NTFS etc)
someone cn help me how to split and rejoin the streaming video(MPEG4)
or any other patch, i can't use other software tools also
if possible help with some codes
thanks
Why can't you convert to NTFS? Since you didn't fill in your computer details, I assume it's because you are not using XP....
There's really no way around it. That I know of. -
Does your capturing application allow you to split files at 4 gig.?
I use InterVideo MSI PVS (Personal Video Station ) with my card, and that is a default setting with 98SE, have not tried it with 2000 or XP so it may not default there.
I do believe it is not possible to make a larger file with FAT 32 due to 32 bit numbering and cluster size, and think only 28 bits are actually used to count clusters.
Cheers,
George -
The only solution for the FAT32 file size limitation is NTFS.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
A couple of choices...
1 - good) Change your OS so that you can use a better file system. FAT32 should not be used for video, you'll regret it soon enough. Both NT/XP/Mac/Linux will work fine.
2 - not so good) Change your capturing application so that it limits capture to less than 4 G.Terje A. Bergesen
FAT32 file size and Pioneer player dilemma
By umniy2000 in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2011, 20:17 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 03:44 -
.dv file too large to fit on FAT32 formatted hard drive - not sure of next step
By CBlanchard in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2010, 00:25 -
12gig file on a 40gig usb2 drive fat32?
By sector999 in forum Newbie / General discussionsReplies: 10Last Post: 8th Mar 2009, 11:55 -
Source File Size limitations using Vegas 6
By video bird in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2007, 22:35
