  1. Has anyone tried this trail product? I install it and all I get is a logo on the screen. If I right click it, I can set options but the program never seems to open up. Am I missing something here? Thanks in advance.
    Tom
  2. u should get sp not lite u can download it a http://www.doom9.net
  3. Thanks for the great link. Maybe I am missing it but I can't seem to find the program there. Can you tell me what it is listed under. Thanks again for the help.
    Tom
    Feb 2001
    Berlin, Germany
    probably Download->encoder...
  5. go to download->encoders and next to it it says full listing click that and it will show up if ur going to convert a VCD with CCE DONT!!!!!! it gives bad quality onlee use it when converting to SVCD..use TMPGEnc to convert to VCD
  6. When you start cinema craft, you will only get the logo screen. This through me off as well, but it is what it is supposed to do.
    To you the program, you need to drag the file you want to encode onto the logo screen. Sounds stupid, but that is what you have to do. I agree with the others, use v.2.5 SP if you can find it, its much better
  7. Thanks to everyone for all the help. I find Cinema Craft to be very buggy. Thanks again.
