I've been trying to convert a DVD to VCD or SVCD using a method that seems to be correct to me.
1. I use VOBEdit to Demux the video and audio to an m2v and ac3 file.
2. I then use AC3Tool to conver the ac3 to wav
3. Use TMPEGEnc to convert to VCD or SVCD. I use the m2v and the wav file as the input files.
Video comes out ok (aspect ratio good, etc) However, the audio synch is quite a bit off.
I'm now beginning to think that it has something to do with the Demux from VOBEdit. The AC3 file that I got from VOBEdit won't play in my Win Media Player as they usually do. I tried to use my DVD authoring software to remux the AC3 and M2V but the software had an error reading the AC3. I then muxed the WAV and the M2V back in to a DVD format. This DVD had audio synch problems.
Has anyone had any luck converting DVD to VCD this way?
I have one DVD that I already converted to VCD. I then deleted the DVD and am now stuck with just a de-synched VCD file. Any idea on how I can line up the audio correctly.
Thanks,
JBreits
josh@breittechnologies.com
How best to convert/get rid off VCD/DVD/HDVD9?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2010, 01:17 -
How to convert E-Book in PDF Format to VCD or DVD
By permataharahap in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2008, 01:00 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 06:35 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
