Hey
i just tried to backup Old School using DVD shrink and everything seemed to be going fine until the end, when it said burn process failed. When i tried to play the copy using power dvd it said this "This DVD title's file format is invalid or this disc might have been damaged. In some rare cases, it might be that the DVD-ROM drive is incompatible with your disc. Please try to play this DVD title on another platform or use the same platform but with a different DVD-ROM drive."
This is the Message dvd shrink gave me..dont know if it means anything?!!?
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 17/06/2003 3:25:04 PM
Nero API version: 6.0.0.11
Using interface version: 6.0.0.0
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <DVDRW IDE1004> Version: 0039 - HA 2 TA 1 - 6.0.0.11
Adapter driver: <IdeChnDr> HA 2
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
CdRomPeripheral : V386 STEALTH DVD 1.0h Stealth Port 0 ID 0 DMA: Off
CdRomPeripheral : V386 STEALTH DVD 1.0h Stealth Port 0 ID 1 DMA: Off
CdRomPeripheral : V386 STEALTH DVD 1.0h Stealth Port 0 ID 2 DMA: Off
CdRomPeripheral : V386 STEALTH DVD 1.0h Stealth Port 0 ID 3 DMA: Off
DiskPeripheral : Maxtor 5T040H4 IdeChnDr Port 1 ID 0 DMA: On
DiskPeripheral : WDC WD200EB-00CSF0 IdeChnDr Port 1 ID 1 DMA: Off
CdRomPeripheral : LITEON DVD-ROM LTD163 IdeChnDr Port 2 ID 0 DMA: On
CdRomPeripheral : DVDRW IDE1004 IdeChnDr Port 2 ID 1 DMA: Off
CdRomPeripheral : VOBID InstantDrive CD 14 VOBID Port 3 ID 0 DMA: Off
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 639MB (654412kB)
Free physical memory: 308MB (315640kB)
Memory in use : 51 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
30.3.2004
NeroAPI
10:22:33 PM #1 Phase 111 File APIProgress.cpp, Line 235
DVD-Video files sorted
10:22:33 PM #2 Text 0 File Reader.cpp, Line 118
Reader running
10:22:33 PM #3 Text 0 File Writer.cpp, Line 127
Writer DVDRW IDE1004 running
10:22:33 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3854
First writeable address = 0 (0x00000000)
10:22:33 PM #5 ISO9660GEN -11 File geniso.cpp, Line 3854
10:22:34 PM #6 Text 0 File Burncd.cpp, Line 3173
Turn on Disc-At-Once, using DVD media
10:22:34 PM #7 Text 0 File DlgWaitCD.cpp, Line 228
Last possible write address on media: 2298495 (510:46.45)
Last address to be written: 2297087 (510:27.62)
10:22:34 PM #8 Text 0 File DlgWaitCD.cpp, Line 233
Write in overburning mode: FALSE
10:22:34 PM #9 Text 0 File DlgWaitCD.cpp, Line 1722
Recorder: DVDRW IDE1004, Media type: DVD-R
Disc Manufacturer: -
Disc Application Code: 64, Disc Physical Code: 193
10:22:34 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 768
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2297088 (2297088) = #2297088/510:27.63
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2297088 blocks [DVDRW IDE1004 ]
10:22:34 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 937
Prepare recorder [DVDRW IDE1004 ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 4704743424, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2297088 | lead-out | 1 | 0x00 | 0x41
10:22:34 PM #12 Phase 24 File APIProgress.cpp, Line 235
Caching of files started
10:22:34 PM #13 Phase 25 File APIProgress.cpp, Line 235
Caching of files completed
10:22:34 PM #14 Phase 36 File APIProgress.cpp, Line 235
Burn process started at 4x (5,520 KB/s)
10:22:34 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2130
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:22:34 PM #16 Text 0 File DVDR.cpp, Line 1485
Recording mode: Sequential Recording Mode
10:22:34 PM #17 Text 0 File Mmc.cpp, Line 18878
Set BUFE: Super Link -> ON
10:22:34 PM #18 Text 0 File DVDR.cpp, Line 1600
Start write address at LBA 0
DVD high compatibility mode: Yes
10:22:34 PM #19 Text 0 File Cdrdrv.cpp, Line 7906
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
10:22:45 PM #20 Text 0 File Writer.cpp, Line 318
22:22:45.166 - DVDRW IDE1004 : Queue again later (Intervall : 11msec)
10:22:45 PM #21 Text 0 File Writer.cpp, Line 318
22:22:45.176 - DVDRW IDE1004 : Queue again later (Intervall : 11msec)
10:37:02 PM #22 Text 0 File WriterStatus.cpp, Line 113
<DVDRW IDE1004 > start writing Lead-Out at LBA 2297088 (230D00h), lenght 0 blocks
10:37:02 PM #23 Text 0 File ThreadedTransfer.cpp, Line 227
all writers idle, stopping conversion
10:37:03 PM #24 Text 0 File Mmc.cpp, Line 20114
Queue-Again-Later on FlushSectorCache
10:37:03 PM #25 Text 0 File Mmc.cpp, Line 20114
10:37:03 PM #26 Text 0 File Mmc.cpp, Line 20114
10:37:03 PM #27 Text 0 File Mmc.cpp, Line 20114
10:37:03 PM #28 Text 0 File Mmc.cpp, Line 20114
10:37:22 PM #398 Text 0 File Mmc.cpp, Line 20114
10:37:22 PM #399 SCSI -1046 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 2, TA 1, LUN 0, buffer 0x0C231000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x2A 0x00 0x00 0x23 0x0D 0x00 0x00 0x00 0x10 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x30 0x05
10:37:22 PM #400 CDR -1046 File ThreadedTransferInterface.cpp, Line 1620
Illegal disc
10:37:22 PM #401 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1620
Could not perform end of Disc-at-once
10:37:22 PM #402 Phase 38 File APIProgress.cpp, Line 235
Burn process failed at 4x (5,520 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=6.1.1.7 , size=24698 bytes, created 25/06/2003 12:18:48 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28/10/2003 5:02:00 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
DVD Shrink Problem?
By LCE in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2010, 07:38 -
Problem using DVD shrink 3.2
By aldago in forum Newbie / General discussionsReplies: 12Last Post: 13th Feb 2009, 20:28 -
DVD Shrink- Reauthoring Problem
By MPO in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2009, 11:42 -
Dvd Shrink Problem
By letty in forum DVD RippingReplies: 5Last Post: 23rd May 2008, 08:09 -
DVD Shrink problem
By lapetite_66 in forum Newbie / General discussionsReplies: 27Last Post: 10th May 2007, 10:21
