I am looking for a program that can convert a non anamorphic widescreen DVD to a 16X9 anamorphic DVD with out too much video quality lost (ex:True Lies) P.S I want to keep the AC3 Audio. Thanks for any help I can get.
Just curious, but what would be the benefit of this? If the extra vertical information isn't there, you'd just be making it less sharp more than likely.
I haven't messed with this much but I would think either of these ways could work.....
Demux with something like DVD Dectypter or VOBEdit, then....
With AviSynth...
MPEGSource("True_Lies.m2v")
LanczosResize(720,360)
AddBorders(0,60,0,60)
(this one distorts a little)
or
Crop(0,60,0,-60)
(this one doesn't distort but you are removing lines at the top & bottom)
Then re-author your DVD with the new m2v stream and your original ac3 stream.
Or not."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Originally Posted by Shudder
I have attempted this by using VobEdit demuxing the vob to mpg and ac3. Using Vegas to crop the video to 16X9 then putting the mpg and mp3 in DVD Architect the video is as good as the original(maybe even better than filling the screen using the TV’s zoom with the original DVD) but I have a bit of audio/video sync problem. I used DVD Shrink to create 1 vob file with no compression. All of this was a lot of work. Just wondering if one program could make this happen.
I've got 4:3 on my mind as I've been screwing with that all day, so if I've misunderstood "non-anamorphic widescreen" as meaning you're working with 4:3 source as I believe I have, then disregard everything I posted above
Too many bong hits."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
So you're saying that if you get a dvd in widescreen but the black bars are just thrown in there because it's non-anamorphic, your tv will interpret that as actual video and treat it like a full 4:3 image? Sorry man, I didn't know that, and that's not a good thing
Good luck
Why wasn't anamorphic widescreen mandated by the dvd specs from the start?
By yoda313 in forum Newbie / General discussionsReplies: 11Last Post: 1st Sep 2010, 19:50 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 15:46 -
vertical resolution of anamorphic widescreen?
By Sean_ve99 in forum Video ConversionReplies: 12Last Post: 7th Jan 2009, 11:41 -
Anamorphic DVD from Widescreen h.264 Video
By trueg in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 16th Sep 2008, 10:47 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15
