Is there a technique for minimizing flicker on the resulting video when capturing Super 8 film through the use of a film projector and videotaping it using a Digital 8 videocam? Are there filters in software to facilitate this process? Any suggestions?
Benny, . . . I cannot answer the tecchie "Why???" but I do believe if you have a friend that has an 8mm Sony analog, you may be more pleased with the results.
I have done several for friends with my old Sony, and flicker never really was much of a problem.
May God bless,
Dwight -
Originally Posted by bennyjal
- to minimize flicker you need to play with the framerate on the projector - I think trial & error type of process (you need to view your video as you speed up / slow down the film) (if that's not working, there is a unit out there that you record from rather than a screen - I think they went from $900 up to about $2k, so they are pricey)
- I can't remember which s/w has this but there is an anti-'bulb' filter around - e.g. when you project film, the center is brighter b/c of the way the bulb is shaped - this filter reverses that to balance the picture (the $$ devices avoid this by lighting the film from behind dimly and letting you record that directly).
I think if you search around in the forums here you will find more - did you try that yet?"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
Annoying flicker from 8 mm film
By mexuser in forum Newbie / General discussionsReplies: 3Last Post: 29th Mar 2011, 19:31 -
Eumig 607D Super 8 projector question
By afoggynotion in forum Newbie / General discussionsReplies: 3Last Post: 22nd Mar 2011, 15:13 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 15:50 -
Super 8 Film to avi
By buckethead in forum RestorationReplies: 6Last Post: 30th Jan 2009, 08:51 -
Super 8 film convert to cd
By joe8915 in forum Newbie / General discussionsReplies: 6Last Post: 5th Jan 2008, 07:52
