Basicly, I am trying to frameserve from DynaPel MotionPerfect. MotionPerfect only supports .avi output, with a chosen compressor/decompressor. So I am looking for a program that calls itself a compressor, but really just makes a psuedo .avi file that can be opened in another program via framserve. I know that there is a plugin for Adobe Premiere, the Video Server Plugin, but that is not a full codec, so to speak, as in you can't use it in any avi encoder program.
I am frameserving to save harddrive space, and time of not having to re-encode twice. Not to keep the video quality.
Have you looked at Pluginpac Frameserver? It s in the Tools section. Seems to be reasonably effective serving out of Premiere and Vegas.
"It supports SonicFoundry Vegas, Adobe Premiere and Ulead MediaStudio Pro."
I'll give it a try.
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 18:12 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 22:31
