  1. In terms of speed and efficiency what is the best way to make a dvd from a movie already stored in your hard drive and how long does/should it take? Any info would be great....thanks so much!!!!
  2. If it's already on the hard drive burn the video_ts folder with the dvd-video setting (in something like nero). can't get any quicker than that
    Dec 2002
    My Swamp
    You don't give enough information to answer your question.
    What format is the movie in ? i.e. AVI , Mpeg , etc
    Is it alredy encoded into DVD compliant Mpeg1/2?
    What are your computer specs? (you should fill the basics in your profile , especially if you are asking questions about speed)
    What software are you using or expect to use?
    Help us to help you
