hi i need to take an mpeg file and somehow get it on a dvd...What conversion tools do i need in order to do this?? stupid question i know....any help would be appreciated....thanks
If it's DVD compliant then all you need to do is author and burn, author section over there <-<-<-.
If it's not compliant then you need to convert it, then author and burn. convert section over there <-<-<-.
Not sure if it's compliant? Check it with avicodec and post the results.
"Art is making something out of nothing and selling it." - Frank Zappa -
It's also a good idea to read through the "How To" section and the "Guides" section,also to the left. It'll save you a lot of aggravation waiting for replies to posts
https://www.videohelp.com/forum/viewtopic.php?t=214450
louris54 is this a question about the same thing ?
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
How do you guys convert mpeg-4 file into dvd?
By tendra in forum Video ConversionReplies: 3Last Post: 31st Aug 2010, 01:34 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
tool to convert dvd to mpeg-1
By sumeshkri in forum DVD RippingReplies: 1Last Post: 29th Nov 2007, 03:29 -
Convert DVD to MPEG files....
By w@ntonsoup in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 10:12
