hi all !
i'm having trouble with my ati all in wonder 9000 pro. I also have an ati tv wonder pci in my possession.
I've done recordings of the exact same vhs tape using both capture devices.
My setup for my ati 9000 is going from my s-vhs player, using the s-video connection, and going into the s-video input of my capture card.
My setup for my ati tv wonder pci is going from the s-vhs player using analog cable into the capture card. (this card does not have an s-video input, to my knowledge)
Both cards are not installed and are not in my computer at the same time.
I've done the old switcheroo between both.
Here's my problem, i'm getting far better results using the ati tv wonder than the 9000. The 9000 gives me shaking and that "tearing effect", but the tv wonder does not.
You can view some samples on this webpage
http://www.powow.com/phscrambler
Just scroll down the page a bit......
I'm beginning to think it's my drivers for the 9000, and ati is of no help at all to me!
anyone have any ideas???
If what you are reffering to as trouble looks like this at the top (the white out on the faces are mine):
This is not a very good example as it get worse but I don't have time to search for a better example.
If it's happening occasionally and occasionally flickering, getting bright then dark. If it also works fine when you view on a direct vcr to tv connection. Then see my post here.
https://www.videohelp.com/forum/viewtopic.php?t=214273 -
Image wasn't uploading had a question here that is no longer relevant. Sorry for the double post but I can't find a delete option.
ATI Theatre Pro 550
By didikai in forum Capturing and VCRReplies: 2Last Post: 27th Feb 2012, 12:15 -
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 13:41 -
ati tv wonder pro
By rcomp in forum Capturing and VCRReplies: 0Last Post: 26th Mar 2009, 23:14 -
Logitech Quickcam 9000 Pro
By Tyler2000 in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2008, 16:22 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27
