thanks to all for the help,this site rules. But..how do i get my svcd's to continue from disc 1 to disc 2...EG:Star Wars..3cdr's 45min,45min,27min resectively. I have to manually skip the disc and hit play...store bought Dvd's will keep going. what do they have that i dont?. thanks for any help you can give me on this.
Nevermind....I just read somewhere that there is no way of encoding or burning or authoring any svcd to do what i want. bummer..that would have been a nice feature....and yes..my DVD player does support it..just not for svcd's..thanks anyway.
Hold on a sec...
I think you've misinterpreted the other post.
There is no way of getting a S/VCD to AUTOSTART (that is, start playing as soon as you put it in) if the player doesn't already support it.
But you CAN author a multi-disc VCD set to automatically start the next disc once the previous one has finished...
This can be done with VCDImager. Unfortunately, as I don't have a multi-disc player, I don't have any experience in doing this. If you read the VCDImager manual (http://www.vcdimager.org ) then you find some info on it.
I've started a VCD authoring article series as well here: http://www.geocities.com/medinotes/vcd/ if you are interested in general VCD authoring.
Regards.
Michael Tam
w: Morsels of Evidence
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 09:59 -
Cannot play Zone 1 disc on my Sony dvp-sr100 DVD player
By lea in forum DVD & Blu-ray PlayersReplies: 12Last Post: 23rd Apr 2010, 14:24 -
Combined 2 discs into one, but disc won't play on dvd-player...
By StrobeLightEpileptic in forum Authoring (DVD)Replies: 5Last Post: 7th May 2009, 22:24 -
Authoring an auto play DVD or editing an exsisting ONE to auto play
By theewizard in forum Authoring (DVD)Replies: 22Last Post: 16th Mar 2008, 12:06 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 16:26
