I have a dvdr which my region 2 player says is the wrong format, i ran it thro dvd decrypter which says there is no rec protection and shows regions 1 to 8. I ripped it ne way and burned a copy but same thing.
I tried putting it thro ifo edit but when i selected region free it found no region code protection, i burned again yet it still wont play.
The error message on my dvd player is "This disc is not formatted for the dvd players region"
Can ne1 explain wots wrong and possibly a solution?
Cheers
Jaffa -
Hi...
Probably your problem is the same that I have it... the disc has a "diferent protection", say that no RCE protection but internally has a program that send you to that message...
Try this link
https://www.videohelp.com/forum/viewtopic.php?t=209892&start=0&postdays=0&postorder=asc&...t=james%20bond
the problem is answer there.
Good look -
I just tried with my problem disc which is a dvd with 4 episodes on, put the nop into each one and it now works.
Thanx again for the link m8Cheers
Jaffa
samsung bd 1500 region code problem
By doctor9824 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Jan 2010, 19:19 -
LG RH2T80 Region code problem
By Travel Ted in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2009, 06:04 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42 -
Venturer sts 75e problem after unlock Region Code
By Chon-ji in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th May 2008, 22:00 -
LG RC299H region code hack problem
By maxa in forum DVD & Blu-ray PlayersReplies: 2Last Post: 20th Sep 2007, 05:37
