I generally test my compilations on +RWs before committing them to +/- R. Up until now, all have been in the 4 -4.2gig range. The other day I tested a 1.6gig burn and noticed that after the initial burn completed the Lead Out/Finalization process continued until the remainder of the disc completed (entire disc burned). With my 811S running on 2.4x Memorex +RWs that was about 24 minutes to complete. Is it normal that +RWs need to be "written to the edge" or is this a configuration issue that I need to change in Nero?
No, I'm from Iowa. I only work in outer space.
babyboo
I have the same issue with my 411S and Nero 6.3.
I happens with Nero and +RW disk only when you use blank +RW disk for the first time. Next time you use already formatted disk, it will take only time needed to burn 1.6 Gig. -
Hmmm. Interesting...
Does erasure prior to reuse affect the formatting? and does it matter whether I do a quick erase or full erase (except for the amount of time involved)No, I'm from Iowa. I only work in outer space.
Burning DVD+R with Nero 7
By solarblast in forum Authoring (DVD)Replies: 6Last Post: 24th Aug 2010, 05:17 -
DVD error while burning in NERO 7
By coinsdrop in forum Newbie / General discussionsReplies: 19Last Post: 22nd Apr 2009, 10:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Burning Videos to DVD with Nero 9
By GeneYuss in forum Authoring (DVD)Replies: 6Last Post: 22nd Dec 2008, 07:11 -
Nero dvd burning, disabled?
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2007, 13:55
