well 1st ive been all through the guides and the forum doing all kinds of searches .. but i run into 1 problem when trying to convert Svcd to dvd... when put in the svcd in the drive and open the folders i dont c my . dat file which is supposed to b in the MPEGAV folder(i dont have that folder)
but i do have a .dat in other folder but the program TMPGEnc wont accept it .. which makes me stuck so maybe someone here could help me plz
I think you need to spend a little more time in the guides section. SVCD's are mpeg-2. The movie file(avseq.mpg) is located in the MPEG2 folder. Use IsoBuster to extract it because you need to remove some extra header info in the mpeg. Here are some guides for putting SVCD mpegs on DVD: https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=SVCD+to+DVD&h...or+List+Guides
i think ur reffering to just putting the svcd on a dvd r .... actually wat i want to do is convent them to dvd format so that itll play on lets say a ps2
The guides still apply despite what you think. Not only that, you won't even have to re-encode your mpegs. If you still want to convert them to a full-blown 720x480 that will probably look worse than the original mpeg, that's up to you. TMPGEnc can re-encode for you but you'll still have to use a seperate authoring program to create the proper DVD file structure. You can find lots of articles in the guides section on encoding, as well as authoring.
mixxez,
Read the guides again. All the info you are asking about has already been posted in the guides section. -
ight well maybe im in the wrong sections... do u think anyone of u could give me a link to the exact page i need plz im hella lost yo
hella lost? please you haven't even attempted to search, you just expect everything to be handed to you, well let me dust off your silver platter for you: https://www.videohelp.com/forum/userguides/171216.php
Originally Posted by mixxez
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
