Hi All,
I'm using Nero VisionExpress to capture, author and burn DVD's from my VideoCam via Hauppauge. Everything works fine so far - good Videoquality even with realtime MPEG2 encoding, no audio sync issues, stable program, etc. But I can't use the whole program since the encoded audioquality is really bad. Especially the high frequencies sound absolutely blurred and distorted. But this happens only when I capture PAL into DVD mpeg format. If I capture to AVI (no compression on video and audio), the sound is perfect. So it must have something to do with the audio encoding during capture. If I capture NTSC (which uses LPCM audio instead of ac3), there is no problem as well.
The only way I can get rid of this distorted high-frequencies is to filter the audioinput with a low-pass at about 10khz which makes the sound really bad. My old taperecorder from 10 years ago recorded in better quality as I can make DVD's with this tool. :-(
Did anyone experience the same problem with Nero VE? Maybe someone can help ...
Thanks and Regards,
-Bert.
Results 1 to 1 of 1
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Bad motherboard or bad CPU?
By videohalp in forum ComputerReplies: 11Last Post: 9th Jul 2008, 11:07 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 20:45 -
nero with bad audio quality?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 1Last Post: 3rd Sep 2007, 05:07 -
I Can't get Nero VisionExpress to see dvd files
By Quip in forum Newbie / General discussionsReplies: 5Last Post: 27th Jun 2007, 00:37
