I HAD FEW DVD KARAOKE SONG. I WOULD LIKE TO COPY ALL THE FAVOUR SONG TO 1 DVD . CAN YOU TELL ME WHICH SOFTWARE TO DO IT AND INFORMATION ??. THANKYOU VERY MUCH
REGARDS
THOZON
Use DVD-Shrink to extract the selected Karaoke song from the original DVD. Rename the VOB file to an esay-to-remember name (e.g. name of the song). Then use DVD-Lab to import the VOB files and re-author your personalized Karaoke DVD with Menus and navigation controls.
I done the way you said but here is a problem. Even the original Karaoke DVD you have 2 audio but after you use DVDshrink to select the song you want. You will not turn off the vocal channel (You see both audio but you can not switch to another audio : same mean to can not turn off the original singer gfor you to sing). You have any more think please post. Thank you.
MP3 - Batch export song number/song title/etc to ID2/ID3 ?
By ralf07 in forum AudioReplies: 5Last Post: 3rd Mar 2012, 02:51 -
A time-lapse video that writes the words to a song as the song plays
By radardetector in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2011, 23:09 -
Can anyone advise me how to copy karaoke dvd songs
By BILLION in forum Authoring (DVD)Replies: 1Last Post: 8th Aug 2010, 18:02 -
help, trying to copy midi dvd karaoke
By chris_j11 in forum DVD RippingReplies: 17Last Post: 24th Jul 2008, 10:11 -
How to extract a song from a Karaoke disc?
By happybighead in forum DVD RippingReplies: 2Last Post: 6th Jan 2008, 08:09
