Hi, I've bought a NEC 2500a dvd-burner, and it kindof works fine but.....
Some of the dvd's I burn do not play in a standalone dvd-player?? I use Nero as my burningsoftware and I'm using Verbatim medias. They all work fine in my computer, but some om them just hang when I try to play them on my standalone?? And it's only some of them?? Has anyone got the same problem?
in advance thanx
GeorgO
If your original has errors, when burned they may not play and actually hang (just come to a dead stop) in the middle of something.
This can be a sign of corrupt media, or even a faulty dvd player.Cheers, Jim
My DVDLab Guides -
I dont know where Verbatim make their media nowadays, but there are bad stuff out. I didnt take the chance on Verbatim media because of a 50-spindle of cdr with very mixed quality, couldnt even read half the disks in the cd writer just after burning them with data, only 1 out of 5 worked in my pioneer standalone. Thats industry today, they make it everywhere, economy rules so if a never heard of before factory in china claim they can do it better and cheaper then they will be allowed to do it and we get to pay for the shit, branded or not.
Thanx for the input guys. I've now checked my dvd-player and it's a Denver 142. I've read under the dvd-player compability section that it doesn't support dvd-r medias. But some of my dvd's worked? Could this be the reason that I'm having problems? As I said, all my dvd's plays perfectly on my computer, so I guess they are allright.
GeorgO -
well, for what's it's worth ... I once bought a NEC - had nothing but playback issues with stuff it burnt. needless to say that drive is now collecting dust in the shop again
portable DVD player cracking sounds then hangs
By dzsoul in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th May 2009, 07:29 -
Slow motion FX hangs DVD players
By Canopus Smoker in forum Authoring (DVD)Replies: 5Last Post: 17th Dec 2008, 17:18 -
VLC Media Player hangs and starts hogging lots of Virtual Memory
By shiningwizard in forum Software PlayingReplies: 2Last Post: 27th Aug 2008, 09:17 -
DVD Hangs in one Area
By gjordan12198 in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2008, 22:37 -
New DVD hangs; copied to hard drive with IsoBuster but cant burn
By bernie01 in forum DVD RippingReplies: 5Last Post: 1st Aug 2007, 17:36
