I bought 2 different drives. A Liteon8x(Returned) and a dual Digital Research(current)8x dvdrw burner. Both do the same thing.
I install the software that is included in the bundle Roxio 6. Before i even get to burn a CD. It gives me an option of what speed i want to record at. Normally, it should give me the options of 1x,2x,4x,8x, etc.. It only lets me select it as 3x (I dont even see the options of 4x and 8x..) what makes it even worse, Nero only lets me select 1x,2x,2.4x. This is driving me nuts! Does anyone know what i should do?
I have winXP.
4 hdds connected to a Promise card.
So the dvd is by itself in the MB IDE.
the jumpers are set up ok.
Can anyone please help??
The latest firmware for this drive is 0357. Try upgrading to it if you haven't already.
What type of DVD disk did u put in? Normally if its 2x, do not expect 4x or 8x.
Sam Ontario -
Even before the drive reads a DVDR it only gives me the option to select 3x (Roxio) or lower (For nero). This is Right before you burn a DVDR. Normally u can click on the burn button and then it will ask you for a DVDR right before it writes to the disc.
I disabled and enabled UDMA on my MB IDE but the same issue still persists. :/ this is fustrating for a technition.
*Ripping hair off*
~ahx -
Nero 6 needs lots of patches. Also use compatible media! Not just 8x media, but 8x media that works with your specific writer & firmware.
The Nero im useing is the newest one that is available for download. This also happends in the newest Roxio easy cd creator 6.
DVDRW 2016UI - DVD Rewriter
By DVD-Writeoff in forum DVD & Blu-ray WritersReplies: 3Last Post: 6th Sep 2011, 13:18 -
VHS to DVDRW recording with Samsung VR330
By ecc in forum DVD & Blu-ray RecordersReplies: 3Last Post: 8th Jan 2009, 16:53 -
DVDRW not recognized by Windows XP
By bmwracer in forum ComputerReplies: 38Last Post: 11th Sep 2008, 21:33 -
DVDRW works fine on PC, not on DVD Player
By Koopzer in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 03:54 -
Samsung DVDRW Drive Won't Eject
By 888888 in forum DVD & Blu-ray WritersReplies: 4Last Post: 5th Nov 2007, 20:27
