  1. I am trying to create a DVD with 3 movies that are sequenced one after another: So when you select the play button on the menu, it plays movie one, and then automatically goes to movie two, and then to movie three.
    But, when I compile the DVD the first movie ends up blank - I can see the Title / Chapter listed in the structure, but it has zero time and then the DVD automatically moves on to the next movie.
    If I test compile, everything looks good and all of the links look correct.
    Please help with any suggestions as this is getting very frustrating. I don't want to try and recompile the movies as one long mpeg, because I no longer have the original .avi files.
    Thanks.
    Nov 2003
    Houston, TX
    1.4 beta 2 is LOADED with bugs....so if ur using it, that is probably the problem, go back to v 1.3
    josh
  3. With 1.3, I was getting a different error - a "serious error" with the compile.aux and it wouldn't compile at all.
    I have tried compiling each individual movie alone and it seems to work fine.
  4. I've come to find that when I get that error when i either use .vobs for motion menus or i use menu audio made with Besweet......I started using ffmpeggui for audio & stopped using .vobs for motion menus & didn't have the problem anymore
    "Hello. My name is Inigo Montoya. You killed my father. Prepare to die."
  5. I think you are looking for "Play All" functionality. See if this guide helps:
    http://www.photosyndikat.de/guides/more/PlayAll.html
