when i re-auther with dvd shrink and using only the menus and the main movie i have no menu controle at all.
how can i fix this? apreciate any help. thanx
I'll be nice (Because some of the others won't be)
If you re-author the disk in DVD shrink, then the menus will no longer function. Any of the newer version of shrink should warn you about this when you attempt to re-author the menus.
Take a look at the guides section on the left. Do a search for guides relating to dvdshrink and these should clear any confusion that you might have.
kosekjm -
sorry man this stuff is still fresh to me. thanx for not biting my head off. piece
Authoring oversized DVD, then shrink to fit on a disc?
By adamberkey in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2012, 00:39 -
Authoring DVD without a menu?
By Humptydank in forum Authoring (DVD)Replies: 6Last Post: 29th Mar 2010, 17:55 -
How to do a dvd shrink containing only the movie without menu's etc
By vain in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2009, 09:57 -
Authoring so that my standalone DVD player can respond to remote control
By cprelude in forum Authoring (DVD)Replies: 3Last Post: 22nd May 2008, 13:03 -
Should I consider other programs then DVD shrink for DVD9 to 5 authoring?
By geepondy in forum Authoring (DVD)Replies: 11Last Post: 3rd Apr 2008, 18:42
