Greetings,
I am stuck and I really hope someone here can help me. I searched on the web for hours and I was not able to find a solution.
I installed Pinnacle Instant Copy 7 evaluation and it installed a virtual drive with Instant Drive. Even after I uninstalled InstantCopy, the virtual drive is still on. (Of course, I rebooted after the uninstall). I even tried to uninstall the driver with the device driver pannel. I am no newbie, I am a computer engineer since years. I am pretty sure there is a stupid detail that I can't see.
I think the problem is due because I made the mistake to mount an image created by InstantCopy (a .PDI file). When I try to delete the file from the directory, it says it is locked and I can find the mounted files (as a DVD playable tree under the virtual drive.
Any help will be appreciated.
Thank you
Results 1 to 1 of 1
Audio Effect help needed (Pinnacle Studio 11)
By JohnP in forum EditingReplies: 0Last Post: 5th Apr 2011, 05:44 -
chapter help needed for pinnacle 12
By shashgo in forum Newbie / General discussionsReplies: 0Last Post: 19th Oct 2010, 16:40 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
Capture with DC 10 Pinnacle Card with OS Win 2k and Pinnacle studio11
By fjmr in forum Capturing and VCRReplies: 2Last Post: 7th Apr 2008, 18:02 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
