hi
after installation latest ffdshow wmp9 is crashing if i will try to play some avi or whatever...
can i have installed xvid rc3,divx 5 and ffdshow together?
why this is happening? if i uninstall ffdshow everything is fine but i need ffdshow for some movies to play...
any help appreciated..
PS after installing ffdshow GSpot does not see ffdshow? why?
thanks again
You have a couple of options. You could uninstall FFDSHOW and find an older version and install that, or you could go to the FFDSHOW configuration utility and disable decoding of Divx and Xvid files. You can find the utility in your start menu programs group. I have no idea why G-spot doesn't recognize FFDSHOW.
disable xvid a divx files is not option...that is why i want to install it...
but i do not think this is core of problem...
because only wmp9 is crashing not bsplayer for example. why bsp is not crashing too?....so where can be a problem in winmediaplayer9 i guess? -
ok...but it is 2002 so do not know where to get it..
can you give me a link to download it....
thanks in advance
Is this the correct way to install ffdshow just for VirtualDub?
By tigerb in forum Newbie / General discussionsReplies: 8Last Post: 25th Nov 2013, 02:23 -
FFDSHOW won't install on Win2k
By DanielF in forum Software PlayingReplies: 7Last Post: 27th Apr 2013, 06:12 -
Can I install two different versions of FFDShow on a single PC?
By Foxhack in forum Newbie / General discussionsReplies: 2Last Post: 4th Feb 2012, 01:52 -
Is it possible to install two copies of ffdshow?
By Foxhack in forum Capturing and VCRReplies: 2Last Post: 9th Jan 2011, 13:26 -
WMP9 Plays M2TS BlueRay
By wulf109 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2008, 20:10
