  1. I want the first track to play before the menu and then not appear on the menu.
    I figured out how to get it to play before the menu, but how do I remove it from the menu?
  2. using edit function, minimize track icon and text box.... then move over to menu edge - they then won't show up on TV (safe zone).
    Always check helpfiles/instructions before leaping...
  3. Member daamon's Avatar
    Melbourne, Oz
    Hi cayqel,
    I've been using TDA for a while, and have been looking for the same answer for nearly as long.
    rcb has given you the only solution that does the job - there doesn't seem any way to actually delete the button, only to hide it.
    Or, you could try a different authoring tool - like DVDLab on Sonic ReelDVD... They're supposed to be more flexible, but a bit more complicated.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  4. You can do what rcb suggested and then remove the button with VobEdit or MenuEdit
  5. thanks for the help
