Just wondering if the following is possible. Can I capture multiple avi files, at one time, from a minidv camcorder, split them up and then encode them? I would like to be able to save each movie separately so when I go to build a DVD I can then choose which movies I would like on the DVD. I know I can sit at the computer and hit the stop button, which if that is what I have to do then so be it. Just curious.
You can split a DV capture into multiple AVIs at set time points, or by scene change according to the timecode on the tape, and probably other ways too. That may or may not give you exactly what you want. The other way to do it would be to capture one big AVI and split it with a simple editor which is fast and easy.
Multiple AVIs to a single SD-DVD with MultiAVCHD
By jeffdb27 in forum Authoring (DVD)Replies: 3Last Post: 1st Jun 2012, 16:17 -
Saving multiple AVIs from 1 AVI by virtualdub script
By DveD in forum EditingReplies: 1Last Post: 16th Oct 2009, 09:47 -
All-in-one program for multiple avis to dvd with menu and good quality?
By Yaeli in forum Authoring (DVD)Replies: 9Last Post: 4th Sep 2008, 16:01 -
Multiple AVIs to one DVD
By 64RedMustang in forum Authoring (DVD)Replies: 7Last Post: 13th Sep 2007, 19:42 -
multiple AVIs to DVD
By exekutive in forum MacReplies: 2Last Post: 11th Jun 2007, 10:49
