I just tested a Taiyo Yuden DVD-R 4x and it burns at 8x which is good. I burnt 3 GIGS in 7:48 total time.
Is that about right?? in terms of the amount of data and the time it took at 8x??
I figured it would be since 4x at 4.7 gigs of data would be about 15 minutes. Therefore, 3 gigs at 4x would probably be 10-11 minutes. It only took 7:48 on my 8x drive at 8x for 3 gigs.
Just someone reassure me that the time it took is about accurate for 8x?
yes, it is.
[edit] well, it actually looks like it wouldn't be burning at 8x the whole time...but its close -
no your right.they dont burn at a constant 8speed.
it sorta builds over a few minutes -
sweet...I thought it was correct
I have now find reliable 8X MEDIA FOR MY NEC2500A..Taiyo Yuden 4x DVD-R work GREAT! -
Verbatim Data Life Plus MCC 4X media will burn at 8X with this drive too. Bought a bunch of them at Buy.com
dogfather
thanks for the info...do you know if they sell these in stores such as Bestbuy, Office Depot, Staples, Circuit City..etc? -
that is some expensive stuff man.Originally Posted by IgotGAME
The only Taiyo Yuden DVD-R Media i have found in my local BB was thethanks for the info...do you know if they sell these in stores such as Bestbuy, Office Depot, Staples, Circuit City..etc?
Ten packs of Fuji 4x DVD-R "Made in Japan"
As for the write speed of the Nec2500a (uses Z-CLV burning method)
Burning at 8x.
0gb to .8gb is done at 4x
.8gb to 2.2gb is done at 6x
2.2 to end is done at 8x
-ty1er
Taiyo Yuden cutting back on production of optical media
By Kerry56 in forum MediaReplies: 15Last Post: 12th Oct 2010, 01:14 -
Taiyo Yuden Silver Thermal Lacquer 52X CD-R Media (Value Line)
By mccoady in forum MediaReplies: 14Last Post: 15th Sep 2009, 12:50 -
need opinions on blank media - Verbatim or Taiyo Yuden
By pattirose in forum Newbie / General discussionsReplies: 79Last Post: 14th May 2008, 02:54 -
Problems with Memorex Media. Where to buy Taiyo Yuden?
By John Shumate in forum MediaReplies: 11Last Post: 19th Dec 2007, 14:38 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 11:29
