I recently purchased some "True" 8x media. I have a Plextor 708a burner which will burn 4x media at 8x speed. It got me to wondering,how can I tell if these so called "true"8x media are really 8x. If I set say Nero to burn at 8x or Maxium and put either an older 4x or one of these newer 8x blanks they both burn at the same rate. Since 8x blanks are more costly than 4x ones how would I know if some company just didn't send me some 4x ones knowing they would burn at 8x. I was wondering if there some way to check a blank DVD to see what the "true" burn speed is. I know this a wordy post,I hope you can see what I am talking about.
Use the CDVDInfo tool you can download from the Plextor website. It tells you what speed to burn every disc you put in your drive and is pretty accurate.
Its free
Gotta love my Plextor 708a, hate their costumer support. -
Thanks for the reply. I never did find that program on Plextor site but did find a program called DVDinfoPro. It gives me the info I needed. Thanks again
left column has af topic you can read (dvd media, dvd writers) about what does 8x in your writer.
What do you mean true 8x. 8x media should burn around 8-10 mins 4x at 15 mins or so. Hope this helps
James B Elder -
True, 8x will burn in 9minutes and 4x in about 15minutes, but some 4x media will burn at 8x speeds. ukcat was just wondering how he can tell the diff between 'real' 8x media and 4x media that will burn at 8x.
Thats for a full disk too. rumor was when they came out they only did 8x if you did a full disk, if not you only got 4x.
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 05:07 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 13:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 06:52 -
media : blu-ray media range and more
By angel40204 in forum MediaReplies: 0Last Post: 8th Oct 2009, 06:14 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 17:58
