  1. I was converting some episodes in xvid format to mpg2 for dvd purposes. Each episode was about 21-22 minutes in length and I set each one to 12.45% of the final DVD size. I encoded in 2 pass VBR highest quality.
    However, each one seems to be different. I had one that was 480, another about 520, and another about 535MB. I thought vbr was supposed to help get the file EXACTLY what size you wanted? It kinda blows that I now have a DVD that has 3.95 gigs instead of 4.3. An extra 50 megs per episode would be about 10% more room per file! Should I just encode for say 14% and hope it undershoots it again, and if it comes down to it I could always use DVDShrink? Or is there some setting I'm missing to have it be exact?
    May 2005
    Richmond
    What program are you using for this conversion?
    I'm using TMPGEnc PLUS, the funny thing is, I have it set up on two computers,
    1 - Dell Latitude D600 laptop
    2 - Compaq Proliant ML370 G3 (2 processors)
    with the exact same setting, the 22 anime clip is giving me a different file size on both. the laptop yield 860meg, while the server gave me a 1.2 gig file!!
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Shudder - if the original files are different sizes, then the output files will be different sizes.
    pepsei - are both pc's using the exact same version of TMPGEnc?
    Google is your Friend
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Not quite - if they are of different length he output size will vary. But as stated, the output size is set to 12.45% of a DVD, which should mean that each AVI, no matter length, would be encoded to the same size mpg.
    Now, I don't trust such built in calculators - better to calculate the bitrate yourself, and set that value as average bitrate for VBR encoding.
    /Mats
