AVI to divX problems.
I'm not sure what the problem is here... i've converted AVI to divX before without a problem. Anyway, I ripped to AVI from a DV camcorder. I'm trying to convert the raw avi's to divX. The raw avi's have amazing quality but they're way too big. So, i've been using VIRTUALDUB to convert. I followed the instructions on the site here but my output file always has lag/pauses. It's not smooth. It's like the video gets stuck. The video pauses but the audio doesn't.
What am I missing?
Is there any other software i could use instead of VIRTUALDUB?[/b]
Yes they are. I've decided the best way to compress for the web is WMV. It's easy, good compression, no codecs to download, you can pick different resolutions, and most of all, it works.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Common DivX DVD Players AVI Playback problems!
By Baldrick in forum Newbie / General discussionsReplies: 8Last Post: 6th Jun 2013, 09:32 -
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 08:12 -
File conversion problems AVI to Divx
By kaptainm in forum ffmpegX general discussionReplies: 2Last Post: 10th Aug 2008, 19:21 -
Tmpgenc problems with divx avi's, encoder suggestions?
By kitykat_2004 in forum Video ConversionReplies: 1Last Post: 26th May 2008, 01:35
